02dodgeram
Let me start with some background and as much information as I can present so as to get the most complete answer I can. I've got an 02 dodge ram quad cab (the newer style), with a custom made under the seat ported box with 1.7 cf of airspace tuned around 39 hz. Its single chamber housing 2 10" infinity perfect 10.1 with a 4 ohm SVC. They're powered by an infinity 611a monoblock rated 657 RMS @ 2ohms.
My problem is more for the benefit of passengers sitting back there. Basically the ports are attached to the exterior of the box (made out of ABS plastic) very small (about 14.5 inches by 6 inches by 1.25 inches x 2 ports) but I'm very limited on space under my seats. I've already raised them up by about 2 inches to fit the box, so I really can't go any higher.
The box itself is made out of 5/8" ABS plastic from a mold to custom fit my truck with a 3/4" MDF top. I've stuffed it with polyfill to try to give it more airspace and lower the tuning frequency a little, but again, I'm very limited in my options. I haven't sound deadend anything except for directly behind some MDF baffles created for my front 6x9s, but I plan on stocking up on second skin damplifier pro and dropping in about 200 sq ft of deadener when my cashflow permits.
My problems are:
1. In the back seat, I'm getting some pretty severe cancellation (gets decently loud up front, but in the back you can only feel the bass and hardly hear it). The subs are firing upward into the seats, as thats the only place for them to go.
2. My subs bottom out pretty quickly (if I had to guess I'd say around 30 hz). Is there any way to correct for this? I understand that tuned at 39 hz + polyfill should be acting like its around 37, but there's some pretty severe excursion starting at about 30 and the low end disappears. Am I up the creek without a paddle since I'm tuned so high, or is there any way to trick the subs/box?
3. Is there any more permenant way to secure my rear view mirror? I've wrapped it with rubberbands, and it still vibrates like crazy (virtually unusable).
I'd love to wall off my back seat and throw in some 15s with around 2k rms, but my wallet would get pissed at me and go on strike.
Before I knew any better I would have guessed I needed a bigger amp, but after snooping around here the last few weeks, I realize adding more power to try to compensate for the low end would probably result in some pissed off subs. Would I be better off going sealed, and if so, would a bigger amp be in order to try to make up for the lost SPL. I bought the perfects off crutchfield during their BOGO deal because I want to maintain some SQ for when I don't feel like a wigger, but obviously now that I've gotten adjusted to having subs, I've been bitten by the SPL bug.
If swapping gear is my only option, I'm open to recommendations, and since car audio has now consumed me, I don't mind saving up for something impressive. Obviously, as with the 100s of other threads typed in all caps and with no respect for grammer or spelling, I want the best for the least amount of money, but man does reading those threads get annoying, so the sky is the limit and if it takes me 6 months to save up, so be it. I've already got my eye on some CDT comps for my frontstage as my infinity kappa 6x9s simply DON'T HAVE midbass.
Thanks for any input! I tried to be as thorough as I could, but if I left anything out, let me know. I'm sure I can find a digital camera if pictures would help.
My problems are:
