Sub bottoming out???
Loudmp5
skyhigh&banginlow
So my box is a lil big bout 1.15 after sub displacement its a sa-10 and the box is sealed sub is getting bout 900 or so rms running off a rf t1000 amp on heavy bass notes when it flexes most it pops or something (makes a popping noise i can turn it down one volume level and it will stop
Around the sub itself? I just used silicon around the rim, let it dry and stops leaks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif No gluing involved, comes off too.
So were my negative lead bolts to the terminal was turned in and i think it was hitting the cone i turned it back facing to the side how its suppose to be and then put it back in the box it could have turned again but if not what else could be making the noise there are no air leaks and the box is about 1.15 after dis. and its a sealed box
Loudmp5
skyhigh&banginlow
Loudmp5
florence az
Loudmp5
