Digital Designs
Aclministrator
Ok, heres the story. I have a 15 inch DC level 4 with level 5 coils. I built my own box. It is around 3.3 cubes tuned to 32hz. The box is built for sub up, port back. The slot port goes across the bottom of the box all the way from one side to the other. Now, I used my DMM to set the gains so my ap15001d is sending the sub like 1200 RMS or so using Decafs test tone for amp setting. Well, the sub sounds awesome from the front of my car, but if you are back by the sub(2008 mazda 3 hatch...) it has a really loud almost slapping noise or something. It is hard to explain. It just sounds like plastic hitting plastic. The sub gets a TINY bit warmer in the center, but my old FI BL got a lot hotter off of around the same power and I never had an issue, I think it is a normal warmth if that makes sense. Anyways, the reason I am thinking it could be the box, is because when I planned it out, I didnt think about the port opening in the box being underneath the sub. It is also hard to explain, but if you look through the cutout for the sub from the top, you can see into the port opening a little bit(about 1/2 inch at most) Is this the reason for the slapping noise? Or could my sub be bottoming out? It does it from about 20 volume up to 26 volume(where I have the gains set for...) and it obviously gets gradually worse as the volume goes up. I know this is super long but I am stumped...
