strapped amps
That doesn't sound right at all. .25 ohms is really low for daily, unless your imp rise is like 4x. Have you clamped to see output power and imp rise?
havent officially clamped yet but on burps my voltage can dip down to low 10's
I would bet you are sitting at 2 ohm strapped. I don't see them holding up that long at .5 strapped.
well im not extremely familiar with how amps react when strapped together but i am posotive that my subs are dual 2 ohm/each sub is wired
in parallel to 1 ohm/and the two subs together are wired in parallel to .5 ohm final load
well im not extremely familiar with how amps react when strapped together but i am posotive that my subs are dual 2 ohm/each sub is wired in parallel to 1 ohm/and the two subs together are wired in parallel to .5 ohm final load
Well the reason we are asking and I would say perhaps taking a look even pulling a sub out to check it over is because .25 per amp is very very low and if you dip into the 10s on a burp you would have a very good chance at killing the amps during daily play. We are not saying it's not possible, but something just seems off a bit.
x2
well it just seems like they should be louder at .25 each. when i had one m3a on both subs at .5, my voltage dropped to 12.2.
if i have two m3a at .25 on the same setup then it should be dropping to like 8.7 volts or something. it doesnt add up. the wiring says .5,
but the performance says 2 ohm
If you are truly at .5 ohm you are limited in power by your electrical not the amps possible power. Adding amps/power is not always the answer in order to get more out of the setup. If you drop much further in voltage then you are you will end up with some pricey fog machines.
if i am indeed at .5 strapped then what would you say is a safe working
voltage to try and stay in?
if i am indeed at .5 strapped then what would you say is a safe workingvoltage to try and stay in?
You need to rewire the subs in series/parallel for a final load of 2 ohms (1 ohm each amp). Use a DMM to see what the nominal load is to check your work
ok then, ill stay above 12.65 until my other alternators get here. that way i wont have to take the subs out of the
box when i do a spl contest. i can fit two big alts on my truck and maybe three with some mods to the inner fender.
these amps should last this way for a few years if i can keep the voltage above say 13. btw does anyone know about
how many amps these draw at .25 ohm
1970cuda
1970cuda
alabama
1970cuda
vegang
vegang
