strapped amps
1970cuda
i have two dd m3a strapped together on two dual 2 ohm voice coils. the 2ohm coils are wired parallel
to give 1ohm per sub and both subs are wired parallel to give a final load of 1/2 ohm. does this mean my amps are at 1/2 ohm strapped ? in the dd manual it says not to bring speaker impedance below
2 ohms when amps are strapped.
i have two dd m3a strapped together on two dual 2 ohm voice coils. the 2ohm coils are wired parallelto give 1ohm per sub and both subs are wired parallel to give a final load of 1/2 ohm. does this mean my amps are at 1/2 ohm strapped ? in the dd manual it says not to bring speaker impedance below
yes
the reason they recommend a minimum 2ohm load when strapped is because each amp sees 1 ohm....if you are at .5 ohm strapped, each amp is operating at .25 ohm....good luck.
sorry, i posted before reading thread. i know that by strapping two amps together they act as one large amp but
i thought that by running the current from the subs, through one amp, through another amp, and back to the subs
would raise the impedance. if my amps are at .25 ohm each then shouldnt my 250 amp fuses have been fried long ago.
yeah, .5 strapped is pretty low. Might be ok for burps, but daily I wouldn't recommend it. Have seen .7 strapped daily in a few installs without problems
this has been my daily driver for five months with no problems. i only take the amps
into clipping(via the dd bass knob) for some demos
this has been my daily driver for five months with no problems. i only take the amps into clipping(via the dd bass knob) for some demos
That doesn't sound right at all. .25 ohms is really low for daily, unless your imp rise is like 4x. Have you clamped to see output power and imp rise?
1970cuda
1970cuda
alabama
1970cuda
BP1Fanatic
BP1Fanatic
