starting my 1st sound system build- need assistance plz
also found this one:
1500W RMS Class D Monoblock HFi Series Amplifier (HFi 1500D)
onyx still better?
the link didn't work there. Those are all mediocre amps at best. They get the job done, But I'd rather spend the same amount on a piece of used equipment and get something top notch.
For the box you're looking for, you'll need to raise your budget. It'll cost at least $200. We've got several designers and builders on here that can help you accomplish exactly what you need.
For a sub, I'd personally recommend a 12" Gcon with D2 coils: GCON-12 Sound Solutions Audio 12" 750W GCON Series Subwoofer - SSA STORE
And for an amplifier, kinda a tough one. The ones you listed are nowhere near Rockford quality... Here's actually a really good deal on an amp for you, and it's still brand new: http://www.caraudio.com/forums/amplifier-classifieds/549814-clearance-deals-solid-audio-mono-amp-new-600x1.html
It won't push your sub to the max, but I think it's your best option on your budget.
Again, the Audiopoop and MB Quart are fine, but they are of the lowest acceptable quality. They will get the job done however. And should last for a couple years at least.
If you could really afford it, I'd be all over the AQ1200, top notch amp. Underrated power: AQ1200D Amplifier
Also, I guess another subwoofer option would be the Alpine Type R, D2 of course: Alpine SWR-12D2 (swr12d2) 12" Dual 2-Ohm Type-R Series Car Subwoofer
..a sub that works and takes good power daily:
Obsidian Car Audio
One or 2 of these would actually be my primary choice, I didn't link them because I thought they were out of stock.
Kicker DCVR122 (07DCVR122)2 ohm Final Impedance: Dual 12" CompVR Loaded Vented Subwoofer Enclosure/Box
from sonicelectronix. How would that go with that onyx amp?
Nope. Crumby subs, one of the worst boxes. You need a custom box built for whatever you get, unless you want to run sealed.
The Obsidian Audios or the Type Rs are your best bet if you want anything decent and to stay under $150 each. If you don't mind giving up a good portion of your trunk, I suggest a single 15" of either one. If you want to only give up about half your trunk or less, I'd say two 10" Type Rs.
i would do two ssa dcon 12 d4 and an ia 5.1 the amp is rated for 450 at 1 ohm but has been clamped in the 6-700w range and its small throw in a custom box tuned around 32hz and you will be happy as well as decently loud
this adds up to right over 500 minus the box but i have installed this a few times in various cars and its made me happy customers every time
cobaltitaliano
cobaltitaliano
WI
cobaltitaliano
