Speakers start screeching a few minutes after turned on
  • 4
Thugzord
I have an android 7inch double din deck, 2 alpine type R 10inch and a zues amp from hifonics. For over a year everything was working correctly, then about two months ago, after about 5 minutes of listening to any audio mode, the speakers start screeching softly to loudly and don't ever stop untill the system is turned off. Music is still coming through but the screeching is intolerable. Please help!!!!!
Sometimes an internal fault with the head unit will cause this. I lost a couple midranges to a head unit failing like this. Also if RCA cable is pinched somewhere and shorting to ground you can have similar experience.
Tore it all down, put it all back together, grounds are making good contact, RCAs seem fine, not pinched or loose. But the problem is still happening. Its weird too, on a hot day, the screeching happens much sooner than if its really cold out. I've been dealing with no tunes for months now and I'm loosing my mind. I'm about to replace the head unit but I've been trying to avoid that. If I do replace it, any suggestions under 400 dollars?
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
202
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
343
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
186
38
Thugzord
Thugzord
Mesa az
Thugzord
    May 24, 2024
