Help
Ive been having some problems with my subs and amp and i have no clue what the problem is im running 2 12" 1000 w kenwood subwoofers and a 2000 w kenwood amp ive checked all the connection numerous times and taken it to the shop 3 times they keep saying its the ground they replace it and a day or 2 later they quit working in a middle of a car ride ive turned off my car waited 10-20 min and turned it back on and nothing id appreciate any feed back
Have you tried running the ground all the way back to the battery? Double check all your fuses, and consider upgrading your big three.
I had the instaltion done somewhere and they just keep grounding it in the trunk on some other grounds im kinda scared to touch it becuase if i do it voids the warranty :/
You can still check the fuses without voiding anything, I would recommend telling them all the headache you have had and try to get them to run the ground straight to the battery. It would probably be fair if they want you to pay for the materials. However, I would also say wait and have a more experience member chime in on this before you pay for anything.
The_death_skull
The_death_skull
Pittsburg PA
HoneyBadgerRy
