Speaker only playing at high volumes...?
Mills561
BURR
I have a set of CDT audio CL-60 components I recently got installed. They are hooked to a small Hifonics amp. For some reason, one of the speakers is only playing at high volumes. From about "0-15" it's not playing at all. "16-30" it cuts in and out. "30-35" it plays without any problems. What gives? Bad wiring? Bad RCAs? Thanks.
Thanks for the replies. It's a strong possibility that there is not enough metal contact. I **** at stripping wires haha. I'll check it out tomorrow in the daylight and hope that solves the problem. Thanks guys
Still having problems. Was messing with the wiring yesterday... re-did the speaker connections to the amp. After the first time the right speaker was still cutting in and out except at high volumes. The woofer was continuously playing, but the tweeter was not producing. Re-did the connections again and then the right speaker was fine but the left was getting no power at all. Does this sound like an amp problem or speaker connection problem?
I am using a 4 channel amp so later today I will try to switch the speakers to a different channel and hopefully that will solve the problem.
Mills561
BURR
Mills561
Palm Beach, Florida
Mills561
