Resign from further use of your computer.you have modified and modified, now put more in there and see if it flexs, you are missing the point, if you add more sound pressure and sound waves without modifying more you would have more flex from more preasure and waves, more pressure and more waves is more dbs...
He seems to be missing that flex is just the body panels moving due to bass, but since it's not aligned with the woofers, it's at least partially out of phase. I'm not an SPL guy, but I wouldn't be terribly suprised at all to hear that you can LOSE SPL by upping power this way. Lets say with 2000 watts you have almost no flex, body panels aren't moving. Suddenly when you go to 3k, the roof finally gives and begins to flex on your burp note. I'd imagine all that roof area out of phase with your sub would do more harm than the extra 1000 watts helped.This thread is seriously going to fvck up some noobs' basic understanding on sub stage output in CA.
Look, Mr. Notre Dame, your logic is flawed. Saying the lower volume of a car's interior space will cause less volume to be pressurized and therefore increase the sound pressure in that space is true, but what you're doing is jumping to conclusions and saying that AUTOMATICALLY means more flex is flat out wrong. Flex is the enemy in this scenario since all you're doing is acoustically exciting the metal in the car's body which will lead to cancelation and...LESS output. This is why you deaden. This is why you brace. It's not just for the car's protection.
So you're trying to tell me that if you had the same system in a '79 Celebrity Classic wagon and a Dodge Magnum (assuming volumes are equal), then the Magnum would be louder due to more flex? Think again.
I totally agree with you, I KNOW flex is bad, but when you watch the videos it kinda gives you a idea of that subs output if you know all the factors, I AM BY NO WAY SAYS FLEX IS GOOD... just that flex came from the amount of pressure the more flex the more pressure.... but you do not lose spl because of flex, amd if you do i'm sure the amount is a db or less...This thread is seriously going to fvck up some noobs' basic understanding on sub stage output in CA.
Look, Mr. Notre Dame, your logic is flawed. Saying the lower volume of a car's interior space will cause less volume to be pressurized and therefore increase the sound pressure in that space is true, but what you're doing is jumping to conclusions and saying that AUTOMATICALLY means more flex, which is flat out wrong. Flex is the enemy in this scenario since all you're doing is acoustically exciting the metal in the car's body which will lead to cancelation and...LESS output. This is why you deaden. This is why you brace. It's not just for the car's protection.
LOL I hope he trollinand you don't get waves on video? I bet you do.. record it with the volume up and I bet the camera picks up waves, you can't see 'em with ***** eye, only in video, unless you really think peoples car are waving like that, and if you really have that much power with very little flex i want to see some videos... cuz I don't believe you!!!
Sometimes it's that minor, sometimes it's not. Just keep in mind that flex you're seeing in those videos isn't telling you everything. It comes down to the resonant frequency of whatever panels are doing that flex. You can't always tell how low it will dig or even (honestly) what kind of output you can expect and this is why I'm never a fan of using user videos as an indication of how well a sub stage performs. There's too many other factors, your car being one of them. Add in to that equation the use of CLD on those panels, thus lowering the resonant frequency, and you'll end up with too many variables to say flex is the key indicator.I totally agree with you, I KNOW flex is bad, but when you watch the videos it kinda gives you a idea of that subs output if you know all the factors, I AM BY NO WAY SAYS FLEX IS GOOD... just that flex came from the amount of pressure the more flex the more pressure.... but you do not lose spl because of flex, amd if you do i'm sure the amount is a db or less...
The reason I use the Celebrity vs Magnum debate is because of the thicknesses and types of metal used as well as the different methods of bracing and addition of structural rigidity. That solid sheet metal on a Celebrity requires more force and a different resonant frequency in comparison to the aluminum used on most of the newer cars with the goal in mind to have lower overall weight and better fuel economy. 1/8" aluminum doesn't require as much energy to excite as 1/8" steel, which is why you're going to see the aluminum flex more on the same power and output frequency.if they were equal they should have close to the same flex....
sound waves are visible if they have something to move....
That still does not make the wave visible... you can see the medium move in correlation with the wave. You can not see the compression and rarification of air moleculessound waves are visible if they have something to move....https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDAQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DN8q4xAL2WpU&ei=xrscUvCvAqTqyQGcioCYBw&usg=AFQjCNE3HOG_1TL9rB6puTk0CM_v5plDEA&bvm=bv.51156542,d.aWc
agreed, but i wasn't trying to get all scientific, the medium(car) was still mimicing(flex) the waves...That still does not make the wave visible... you can see the medium move in correlation with the wave. You can not see the compression and rarification of air molecules
