sound deadening...
budahbuddy803
Aiken, SC
Is this a good buy? Is this stuff a cheap product? Is 100ft^2 enough to fully do the doors and interior of an ext. cab ranger? I am just trying to see what i will need to buy to fully deaden my car. Where else is a good place to buy quality deadening? I am sorry, this is the first time i ever considered using deadening. I will get a new truck soon and before i start installing equipment i want to deaden it. All help is appreciated.
I just did my trunk completely in RAAMmat 2 days ago and I'm totally impressed with the results. This was also my first time using deadener and now I feel completely stupid for not doing it sooner with my previous install. You will not be disappointed.
Don't mean to thread jack....but i was going to be deadening my car and was going to use Damplifier along with a closed cell foam, but wasn't sure if i should go with Overkill or Ensoline MLC.
Overkill is priced at ~$1.20/sqft
Ensolite ~$0.85/sqft
Is there any reason to pay the extra 35 cents per sqft for Overkill?
Also does anyone know of better/cheaper closed cell foam that can be used for sound deadening a car?
Thanks in advance
I just got my floor area finish last week with Fat Mat & it turned out awesome. I did use extra adhesive to the back & to the floor, Because folks om SMD forum said it wasn't worth a F***. I don't think is asphalt based because it does NOT have that smell to it, like Elemental Designs stuff that I have used on a previous project. I will post some pics.
so should 80ft^2 be enough to pretty much completely do the interior of a ext. cab truck? I want to do atleaste 1 layer on the floor, side, doors, and maybe roof.
From the looks of the deadener show down i like damplifier or damplifier pro..
or would i be better off getting 1 roll of RAAMaudio's deadener. It says its 62.5ft^2. I just dont want to not buy enough. If i buy and install and fall short i will have to leave my entire interior dismantled until the other stuff ships to me because i wouldnt want to take it all out again...... Any help on how much to buy for an EXT. CAB TRUCK? (most likely ranger)
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
budahbuddy803
budahbuddy803
Aiken, SC
blackbonnie
    Jun 1, 2024
    May 31, 2024
