Sound deadening for tire area in trunk ?
  • 2
mastershake575
184
Dallas
I'm getting a new subwoofer setup in my car in the next couple of weeks and the box will take majority of my trunk (the spare tire will most likely have to be removed).
There's a wooden sheet that covers the spare tire. Once I remove the spare tire there will be a large gap between the wooden sheet and the gap where the tire use to be (the subwoofer box is going on top of the wooden sheet).
I'm sound deadening the trunk but is there something cheap I can shove in the gap that can help with the deadening ? (for example can I shove some quilts or towels in the gap ?).
I hope this makes sense (kinda of a strange question).
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
87
mastershake575
mastershake575
Dallas
audiobaun
