joelowrider
I am looking for a ported box for fi bl 12in fully loaded
size has to be max 23 in wide 13in deep and 19in tall
if that wont work 46 in wide 13 deep and 19 tall for 2
32 hz
1.8-2.5 cube ft per sub
it says 12-16 squre in of vent area per cube ft
Fs: 38.7 Hz | 37.8 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 05.79 | 5.93
Qes: .39 | .37
Qts: .37 | .34
Mms: 177g | 186g
Cms: 0.96mm/N | 0.96mm/N
Sd: 481cm^2 | 481cm^2
Vas: 30.9 l | 30.9 l
Spl: 88.0dB 1W/1m | 88.4dB 1W/1m
Bl: 12.8 N/A | 19.0 N/A
Xmax: 21mm
Rms: 1000W *
Sealed box: N/A cuft
Ported box: 1.8-2.5 cuft @ 30-37Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.750”
Displacement: 0.15cuft
32 hz
Qms: 05.79 | 5.93
Qes: .39 | .37
Qts: .37 | .34
Mms: 177g | 186g
Xmax: 21mm
Rms: 1000W *
Sub OD: 12.500”
Cut ID: 11.125”
