Someone PLZZZ HELP!
ti_27
If anyone can give me some advice I will appreciate it...Okay here is my problem...I went out a couple days ago and got some new subs, Alpine R's...I hooked them up to my box and everything worked fine for about a week...But I had been having some problems with the terminal cups on my box because I have to use these stupid bananna plugs and they keep comming out, so I went to buy some new terminal cups and I took one out of my box to check to see if the new ones would fit, well when I put the old terminal cup back in (because the news ones didnt fit) and turned my stereo on my fuse that runs to the battery under my hood blew...Everytime I put a new one in it still blows...I cannot figure out what the problem is because I didnt change Anything at all...Can someone plzz help?? Why did the fuse start blowing out of the blue?
You must have moved a power or ground wire on the amp. Check your amp connections. Also check the power wire running under the hood. Insure there are no breaks or splits in the line.
ti_27
ti_27
Lexington, KY
ti_27
