Someone check this.
bigred78797
Audiobahn Junkie
Heya guys im about to try and redo my System with new stuff. Right now i have what's in my sig. But im trying to get two 15" Treo SSX's, Custom made quad 2ohm VC. Im going to use 8 A8000T's since i already have 3. This way when i decide to go competition i already have 3200w per sub ready to go... hopefully. While at work i tried to think things through and draw out a wiring diagram.. the only problem is, is that it has been over a year and a half since i have done an install of this magnitude and im having trouble remembering how things are wired. So Could you guys look at this poorly draw graphical skematic and tell me what needs to be changed. I'm about to order my HO alt and the batteries that i will be using are a red top to replace the stock with 4 yellow tops. I figured 1 for every two amps would be enough. I will also be putting my A6601 six channel amp in for mid+highs. Anywho check this out for me.
OK so, I probably need a dual alt setup. The batt wiring is good ( all wired in parallel with the Main Batt/Alt ) i did leave out the relays so i won't drain my batter when i turn my car off. And i left out the fuse Blocks. But other than that it looks good? Just to let u guys know ill be running 0/1 or 0 guage wire from the front to the back batts then splitting it off into 4 ga per amp ( only about 2 or 3 feet long ) I already did the Power wire upgrades up front but im probably gonna upgrade to 1/0 ga wire (Alt to Bat)(Bat to Ground) when i get the new alts. NOW one more question. You think it would matter if i used 8 guage wire for speaker wire, rather than that cheap generic speaker wire??
They need some wire that glows when current flows through them... that would be friggin awsome. anyway thanks, Soon i will go on even more devastating Bass Rampages around town HA HA HA.
bigred78797
Audiobahn Junkie
bigred78797
Fort Meade, MD
monte_carlo97
