so how overrated are hifonics amps?
PatFitz9
the only amp i can find that isn't wayyy to expensive for my 18xxx are hifonics. they have a 1500, 1600, 1800, 2000, 2200. i know that there are new black ones and silver ones, is one better than the other? and i want to have a real 1800ish watts. what should i get?
Bump for an answer because I ordered a HiFonics ZXi 8006, should I be worried?
RMS @ 4-Ohms: 4 x 55-Watts + 200-Watts x 1-ch
200 watts is already a little on the low side, I hope it doesn't put out even less //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
IMO whether you go w/the 1800, 2000, or 2200, they'll be close enough in actual power that it would be hard to tell which is which. 400w when you're talking about 1800 isn't a big difference.
Agreed. Also i would get the newer black one because it looks NEATO BURRITO!
Good little amps for the money. You won't be disappointed.
Agreed. Also i would get the newer black one because it looks NEATO BURRITO!Good little amps for the money. You won't be disappointed.
Sweet, thanks for the assurance mang. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I got the one I mentioned above new w/warranty for $300 shipped. Good deal? Is there a good possibility it won't be putting out 200w on the sub channel? Ugh, I may have to buy a mono block later on in life and use this 5 channel for the components.
a true 1800watts rms...id prob say bx2005d will do that ease at 14v. but i would save the $50 or so and go ahead and go with the bx1800d: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14111
like mentioned above, 200w isnt a dramatic upgrade when dealing with that much power already. use that extra $50 into some big-3 upgrade with 0/1ga wire //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i have this amp, its works great and it pounded the hell out of my fusion power plant at 2 ohms
hifonics are pretty good, expect an overating ofa bout 100-200w.
I assume you are talking about their mono blocks? 100w off of my fifth channel would be half it's power @ 4 ohms. //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
PatFitz9
PatFitz9
Chicago
yacob.naif
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
