Sketch Needed for Subs
Po.Sic
Hey guys,
I have 2 Hifonics AS12SQ subs which will be powered by a bxi2006d, currently i have a prefab box //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif , disgusting i know. Any chance someone could post up a sketch of a box build for these subs? Im looking for pure SPL.
Trunk Dimensions:
Max. Enclosure Height: 21
Max. Enclosure Width: 45
Max. Enclosure Depth: 41
Sub Specs:
Subwoofer Size 12"
Dual Voice Coil Yes
Impedance Dual 2 ohm
Peak Power Handling 1800 watts
RMS Power Handling 900 watts
Woofer Surround Rubber
Woofer Composition N/A
Sealed Box Volume 1.5 cubic feet
Ported Box Volume 1.5 cubic feet
Sensitivity 85.88 dB
Fs = 37.32 Hz
Qts = 0.38
Vas = 21.5 Liters
Xmax = 22mm
SPL = 95.65dB @ 2.83v
If i am missing anything, let me know i will get it up asap.
Thanks!
alright guy's help em out i know i got sketchup off of here someone was glad enough to help me help this guy out im getting him the box built by me and actually a friend of mine save em cash he just needs the sketchup would appericate the help guys thanks:).
Thats what I'm questioning... a pure spl car is much different from a daily driver tuning will will be drastically different.
as far as power, I'm questioning what is the ratio of what the amp will put out against what the drivers will take...
If you have a lot of power to spare you can work with a lot more port (which can be better for SPL) if your over powering the drivers you may not want as much area.
So refer to my first question above and I can help out with the design.
Po.Sic
Po.Sic
Macomb, MI
audiobahnuser18
