EAD
Hello all,
I am new here, but I plan to stick around... finally got my amp out of protection mode after a faultly installation by a local audio-shop. I think I'll stick to what I know and the hobbiest heres knowledge.
Finally I was able to get everything going, but now I need to set everything and the guides I found are beyond on comprehension.
I have Audiobahn A1200N Head Unit, Audiobahn A2381T and two 12" Audiobahn subs. I forget the model number, but they are from about 2002, and are rated 1200W RMS each, true or not the amp isn't too powerful.
The amp outputs are,
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 200W x 2
THD at 4-Ohm RMS Power: 0.02%
Bridged RMS Power @ 4 Ohms: 560W x 1 @ 2 Ohms
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 10-40,000 Hz
Signal to Noise Ratio: > 100 dB
Basically, I need to know, how fair gain should be up approx, and bass boost yes or no and and approx of sub sonic freq. From there I should be able to adjust the lpf and hpf by the audio files and by ear. The above are the confusing parts to me. I will also turn everything off and flat on the head unit.
Thanks all, I look foward to being here
Ed
Preamp Outputs: yes
Bass Boost: 0-18 dB
Ed
