should i still be getting dimming ..
Harleyfx69
audio n00b
i have an 200 amp alternator from one of the big name suppliers,
2 big starting batterys up front on my truck, along with one large audio battery in the back, full 1/0 connecting wire,
running an audioque 2200d, and a kicker 650,
not even running at full tilt i am still getting dimming occasionally ..
is this normal ?
How are the Batteries grounds connected, is the rear battery grounded in the rear to the body or frame or back to the battery under the hood
What type batteries ?
What size or model # ?
am i going to need a DMM to test for that ?
yes.
Your checking for voltage. Definately need one.
Secondly, your big 3 is it in 0 or 4ga, and did you do ALL of the big 3. I know lots of folks that say fawk it when it comes to doing frame to engine block.
Also does it dim driving? Or are we talking about idling. With a 200amp alt thiers no way it should dim cruisin down the road.
yes.
This.
Most HO alts don't put out much more than stock at idle, did you get a amaller pulley ( would up the alt speed) or are you using stock pulley?
it is the stock pully,
it should be putting out over 100 at idle IIRC
and it still does it driving down the road also ,
ill redo the ground on the rear and see if it helps,
if not get another long run to go off the front bat
Harleyfx69
audio n00b
Harleyfx69
arizona
Harleyfx69
