Should I get more Aeroports?
nourkah
I have a US Amps De-1000 pushing a 15" XXX in a 4^3cuft boz with two 4" Aero's. I can't remember what it's tuned to, lower 30's if I remember correctly.
I hit a 140.8 in a local competition. I have no extra batteries or caps.
First of all is that good at all?
The real question is should I add another two 4" Aero's. Would the extra port space affect it that much? SQ? SPL?
http://www.cardomain.com/item/LITPNR3BKPT
Aeroports look like that (mine are a little different).
You can adjust the length of the tube in all four easily to change the length overall and adjust the frequency.
The extra two ports would take up a little more room, but it wouldn't be a huge amount and I could take that into consideration when i readjust the frequency. ..
if you add two more 4" aero's to your set up, I would expect the tuning frequency to jump like 20-30hz keeping everything the same length as original. I bet you dont have enough port length (maximum of 17" with standard aeroport tubing + flared ends) to make it work... 3 aero's though, that may be better. if you are tuned to lower 30's, add a single aero the same length, that should bump tuning up a bit and give you a better frequency. play around with bass box pro and get shit all set up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif good luck!
I don't know if my box is 4cuft^3ft net or gross. obvoiusly i'm gong to readjust the portlength to get whatever frequency i need. basically the question i have is whether or not the extra two ports would b eworth it if EVERYTING ELSE WAS ADJUSTED CORRECTLY i'm no moron i would make sure everyting worked. i want to know if the extra port area woudl help.
obvoiusly I woudl take the ones that are in there now out and adjust the lengths of all four ports to make the frequency appropriate.
nobody has answered this question yet....
nourkah
nourkah
Duluth, Mn
nourkah
