should i fuse?
Fusing for the power cabling should always be in accordance to the ampacity of the cable itself and not the equipment it is feeding power to.
The fusing on your amp(s) is completely incidental and shouldn't be used as a guide for this.
I agree, but...
If the power wire can carry a lot more current than the amps will ever demand, there's no reason not to fuse at the lower value.
For example, a 1000w sub amp with 1/0 wire.
The amp may have a max current draw of 100A, but the wire can carry 250A+.
IMO it would be wise to fuse around 100A just to increase the safety factor.
Also, in response to
no, it should never be less than what is on your amps.
I wouldn't consider that a hard and fast rule.
An amp may be CAPABLE of, let's say, 100A. That doesn't mean an 80A fuse wouldn't provide more than enough current, plus (again) increase the protection factor if there's ever an overload situation.
Come to think of it, before I put in my 100A ANL fuse I was using an 80A agu in an 1100w+ system. That fuse never blew, even playing LOUD test tones.
all amps dont have onboard fuses.
Correct, but you dont fuse close to the positive terminal to fuse the amp.
The fuse to protect the amp needs to be located near to the amp itself.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hundredths, maybe thousanths of an ohm.
Shouldn't even be discussing this.
If you're too stupid to fuse your power wire you DESERVE to have your car totaled by fire.
like i said in my fisrt post im going to fuse it! i asked why people wouldnt fuse it and wether or not a fuse will add a decent amount of resistance.
Mat Dope
Mat Dope
east coast, florida
n2audio
NorthFramingham
    Jun 30, 2026
