should i do it? 2 18" bl's in 16-20 cubes?
Should i sacrifice my explorer?
  • Total voters
    33
they're not fully loaded bro. they only have the cooling option (the limiter is the suspension of the BL's as they are even stiffer than the MT's). the amp is a kx2500.1 with a birthsheet rated 2960w @ 2 ohms, being ran @ 1 ohm so the subs are getting 1500w+. just as a comparison i saw a birthsheet of an RF T30001bd put out 2840@ 2 ohms and 3758 @ 1 ohm. doesnt seem like a stretch that this kx has the capability to put out lots of power for the subs if it putting out even more @ 2 ohms than the RF did (which is being ran on 2 18" mt's).
I love how people always just assume they are getting more than rated power because they are running their amp at a lower ohm load.
Get with the program people.
not like it matters what i assume. with box rise im well over 3 ohms at my lowest point anywho.
i have my gains set to "give" the birthsheet rating (2.9kw @ 2 ohms), i was just saying that i hardly believe the reason for this issue is underpowering the subs and gave what i would consider a fair example of why.
my kx's birthsheet says 2.9kw and in most cases its safe to assume a lower load will result in more power, because in general it will bring the rise down as well. if im @ 2 ohm and rise to 4 ohms...its somewhat safe to assume that being wired down to 1 ohm will give me a final load of under 4 ohms, which would mean more power. no one said since i was wired down lower i was seeing 4kw
More power, sure. More than rated? Probably not.
And I also agree that the current box is too tall. 2 15's would be the better option IMO.
i really wish people would of told me that earlier //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i knew it was going to be tall but it seems i got some bad info in my last thread which resulted in me figuring it would be ok.
oh well. anyone want to buy some 18's?
IgnoreMe
CarAudio.com VIP
IgnoreMe
caraudio.com
AudioAnonymous
