setting up 2 channel alpine
Well... This is actually kinda a shot in the dark, but might lead you in some direction.... I can only assume the fixed/variable is talking about the power supply output which would be dependent on the load....so fixed will give you the same output at both 2 and 4 ohms while variable will give you more output at 2 ohms...but I have no experience in this one
ItsAJeepThing
ItsAJeepThing
Lincoln,NE
keep_hope_alive
