Setting SSF
i know theres a way, i seen someone use on here goin of the crossover db slope and the voltage change between notes or somethin like that, which theroetically sounds right......
If you are trying to set it to a particular frequency, you can use a test tone of that frequency [easiest way]. Whether or not this is the same tone used to set your gain is up to you.
Turn the SSF all the way down. Unplug the subwoofers. Grab a DMM, set it to AC volts and connect it to the amp's outputs. Play the test tone and raise the volume until the DMM reads 1.414V. Then with the volume in that same position, raise the SSF until the DMM reads 1V.
Or you can just set it by ear.
What frequency are you trying to set the SSF to? What is the tuning of your enclosure?
Well my box is tuned to 33 hz, so if I use the equation of SSF_Voltage = 0.707*Sub_Voltage (42.42)= 29.99
29.99 is what I need to set my SSF to on the DMM, correct? Or does that seem too low?
I will use the same 45 hz frequency I use to set my gains.
The formula is correct.
20*log(42.42/30) = 3db
The response is the same compared to the one I posted, just different voltage levels.
However, if you use the 45hz test tone to do this, you will be setting your SSF to 45hz.
Why would you want to set your SSF to 45hz if your box is tuned to 33hz? You'd be setting your SSF a half octave above your tuning frequency. At 45hz the SSF will have attenuated the signal by 3db. And, for example, if the SSF has a slope of 24db/oct (fairly common), at your tuning frequency the the SSF will have attenuated the signal -12db.
In order to use the DMM formula method, you need to use a tone of the same frequency you want your SSF set to.
im allso curious on how i would set my ssf... sorry to thread jack...my box is tuned to 33hz...
Then you can set it to 33hz (tuning), 28hz (5hz below tuning), 23hz (10hz below tuning), 24.75hz (1/2 octave below tuning), any number in between, above or below those listed.
There's so many different "theories" on what frequency to set the SSF to that you'll not find "one" right answer. The half-octave method makes since to me as you're generally safe down to around 1/2 octave below tuning before the sub begins to really unload.
You can set it by ear if you wish. Or pick a frequency and use the method above to set it to that exact frequency.
I wouldn't really recommend setting it a 1/2 octave above tuning like the OP wants to do, however.
There's so many different "theories" on what frequency to set the SSF to that you'll find "one" answer. The half-octave method makes since to me as you're generally safe down to around 1/2 octave below tuning before the sub begins to really unload.
thanks squek!
528hz
Everything'sMiscellaneous
528hz
In the Space between Space in NM
yunvme666
