slicks5150
got a$$ ? ? ?
I see alot of people post to turn this off(subsonic filter) . I have a pa lt980/2 and it turns up and down but not off what should I set it at? I have 2 atlas12's ported 2ft^3 each at 32hz also where should my setting for the lpf be set I have it turned to 30hz same as the subsonic filter at 30hz is this bad?
also does anyone know a good port tuning for the atlas 12's their website only shows a sealed box.or would I be better off going to a smaller sealed box for the subs? rather than the 2ft^3 ported box I have them in now if the ported is ok I just need to know what hz. to port em at.
ok I was told to set the low pass at 80~100hz and the sub sonic filter to 25~30hz I will try that and see what happens now .. .
so does anyone know a good port tuning for the atlas 12's their website only shows a sealed box. would I be better off going to a smaller sealed box for the subs? rather than the 2ft^3 ported box tuned at 32hz I have them in now. if the ported is ok I just need to know what hz. to port em at.
