Setting Gains on MY STOCK system.
Kastlez_
yes i know there are a shitload of gain setting threads but i'm not sure which one to follow for my setup.
I have:
0db tone CD
DMM
High to Low installed with my Stock stereo system
Sub: Fi 15 BL
Enclosure: 3.7ft^3 @ 32hz (ported)
Amp: Saz-1500
Other: 1/0 gauge - Stock Battery
Right now my gains are at 3/4 and my bass knob is set at HALF. What specific instructions should i follow to give my sub about 1200w RMS
NEW QUESTION LAST POST
So i will be following the JL audio tutorial? http://mobile.jlaudio.com/support_pages.php?page_id=143
Do i have to play a 50hz tone and crank the volume to the max i'm going to be playing it?
Not an expert but yeah.
Jl tells u to put everything to 0 (eqs, bass).
I know lot of ppl set it to their preferred level and only then set the gains with DMM.
Coz after u set everything to 0 and go set the gains you shudn really mess with your HU. U can but then ull have to set the gains again.
I do it with the sub attached....all the same steps except don't remove the wiring to the sub....just probe the connections at the amp and turn the gain up till you get your number.
yes, you need to turn up the hu or you will not get to the target voltage
No i have a sundown saz-1500.. hence the first post
sorry, i didnt see that when i scanned ur post. just making sure lol. i dont know about setting gains for a certain rms i usually just make sure it sounds good and isnt too much that my sub cant handle. but i use type-r's and they are rated at 500 rms and can take 1000 a peice so yeah i wouldnt know. best of luck
lol its coo.. thanks for the input!
Square root of power x resistance
So square root of 1200wrms x 1ohm or whatever it may be depending on your target power and how you have the woofer/s wired.
Kastlez_
Kastlez_
Bay Area, CA
Paaco1981
