setting gain with test tone
ok well i set it with a 40 hz to 29volts at 1ohms which i recal is 850rms and the sub barely even moves at all
i set it with a 70hz tone and it hits way harder
so what should i see on the volts for 850rms with a 40hz test tone if its the same then the sub barely moves
well the box is pretty small no dobut its a prefab box for 2 12's l7's
but its way louder ear and pressure with a 70hz tone than a 40
when i set it with a 40hz my gain is barely tuned up to hit the 29volt mark
with a 70 my gain is up more than a 40hz tone i have it currently set at 29.2volts with vol 38/50 and bass on zero on the HU and its way louder compared to the 40hz tune
next weekend i will have my ported box tuned to 34hz so i should just use 34hz test tone and my ssf should be 34 as well right
just cause its louder to your ear doesnt mean it has more pressure
well the sub is barely moving with a 40hz test tone and at 29volts i mean you cant even hear it or feel it nothing moves in the truck
setting 70hz with 29volts its different
where did you get the test tones? are the the same db? is there some sort of sub sonic filter on your hu? is there a built in sub sonic filter on your amp?
I usually use either a 50hz or 60hz test tone and I never see a difference using a dmm.
i got the test tones from the amp sticky off realofexcursion
and when i set the gains with a dmm at 70hz to set it at 29volts when i use a 40hz it goes like up to 65volts and i have to turn the gain down and when i use a low tone and set the gains with that on a normal song the sub barely even moves
king ranch
Banned
king ranch
fl
Immacomputer
