Setting gain, tips?
ARK_SWAMP_RIDER
I am looking for any tips to set the gain on my amp. I am gonna try to do so without a mm, so the gain tutorial isnt much help. I am looking for any tips on how to do it, what to look for, etc. Also, what type of music should be played when setting it, just what I normally listen to or some sort of test track? Thank you for any input.
I'd use something that represents what you normally listen to.
Set the x/o's at a typical frequency -- generally around 80hz, LP for subs, HP for 6.5's. Set the amp(s) gain(s) to their lowest sensitivity (highest voltage). Turn your HU to 75-80% and slowly increase the gains until it starts to distort then back it off a bit.
My amp does not have a knob for it, and I believe it has a left and right gain that are controlled using screws (havent looked real close yet). Would it be the same process with left and right? Also, I know it is crazy, but my 2 10's sound better on full than they do on lp. Will it work the same on that setting? Thanks a lot.
If you don't use a MM when setting a sub amp then you are pissing in the wind. Sub stages can have A LOT of distortion before the human ear notices. MMs are cheap and effective. BUY ONE! Ear methods work for mids and highs since thresholds of distortion are significantly lower in these frequency bands.
I set my gains by ear for years -- when I discovered the DMM method a few years ago I compared my "by ear" adjustment to DMM settings. You'd be surprised how close you can get if you take your time. By ear I usually end up with the gains too low if anything.
However - knowing Ark likes the sound of his subs on Full vs. LP the DMM is probably a good idea.
I need to make sure I got the process right for setting the gain with my bridged amp. I will unhook all speaker wires, set all stuff on the hu at 0, and play a 50hz test tone. I will play the tone, use a mm to test one side at a time to get the desired voltage at each terminal, correct? There is another knob on the amp, I am mindblank and cant seem to think of what it is called, but it is the one that controls what tones come out to the sub. Is that all about right? Thanks.
ARK_SWAMP_RIDER
ARK_SWAMP_RIDER
Arkansas
ARK_SWAMP_RIDER
