Setting Amp HPF Frequency
Decado
On my MTX Thunder 564 I want to set the HPF frequency but it is not marked (bastards), the hpf is 12db stereo also (dunno if that matters or helps). But anyways, I was talking to ologyaudio and he said to take an 80hz test tone (what I want the hpf set to) and play it, then set the amps hpf to 40hz and then turn the frequency up til it is 1/2 to 2/3 the voltage at 40hz. Now, first I just want to check to make sure that is correct, and if it is, how much difference is there between 1/2 and 2/3 (maybe there is a more exact way to do it?).
And also, I'm just wondering, what the difference would be between a 6db stereo hpf and a 12db stereo hpf (hu is 6db that is why i'm changing to the amp), would I get overall better sounding music, louder, more midbass, what? May I have to drop the gains a bit?
Well, I was able to talk to ology and he said that I should try the amp at 40 hz and my HU at 80hz, and this will accomplish and 18db hpf, is this right? Just double checking it here.
Decado
Decado
Minneapolis, MN
Decado
vegang
vegang
