Seriosuly problem. amp smokes when i plug in power and grounf
Lol you guys are funnay!
but seriously it was acting ****ed up. I got a distro block and 150ANL fuse for my fuse between the amp and back battery. I before that I just had a little glass tube one. I still dont get why its shocking the **** outta me if I touch something wrong. I the amp itself spark when it touched metal. It turned on when I just touched the remote wire screw with a wrench and the car wasnt even on. I'll try to free air my sub again. Ive sweated my ass off for hours outside i need a break
I was outisde cutting and crimping and installing wires lol. Then I got to hooking up the amp and it went down hill fast. My truck smells like an electrical fire.
Lol nice sig
uhmm im not sure wtf happened but I reconnected the neg. at the under hood battery and then tried pluging the power and ground in amp and it didnt smoke. It seems to be working fine. And yeah it sparks when the outside of the amp hits metal. So I mounted in on the sub box.
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
693
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Bobby322
Bobby322
TX
jpexpc
    May 22, 2024
    May 22, 2024
