The box is really shallow... not deep at all... are you smoking crack?i just did a build in a truck w/ the ports forward, sounded pretty good. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gifbesides, i doubt hes going for spl w/ 3 re 8's. if he was i'd say subs and port up, subs on pass side port on driver.
i don't know how much room your gonna have between the seat and the box, but if you keep the port low, it'll fire under the seat...
i don't know if you can tell what i did, but thats how i'd do it...
WINNAR! Exactly what I'd do.So, it looks like I'm gonna keep the current design, put all three subs on the same side as the exit of the port, tune the port to 35 Hz, and I may make th port area slightly bigger
I thought about it, but can't for several reasons:to make the design alittle simpler,,,,,why not use an aeroport or 2 on the side of the box? you can always trim them down to get the correct tuning. just a thought....
its going behind a seat you ***The box is really shallow... not deep at all... are you smoking crack?
nG
They'll fit just fine; I've got a mock up all done and they fit with about an inch of clearance //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifWhere are the subs going to go? I have an 05 and the bottom depth of that box can't be more than 9" on the outside, which means 7.5" inside with the top before the curve around 5 or so outside which means 3.5 inside. If the port is on the bottom where do the mags go? I had to fire my 9kv.2 s down just to accomodate the size of the speaker. Even still I i had a port it would fire forward.
What the hell does that have to do with ngsm's post?its going behind a seat you ***
look over my post one more time and maybe youll understandThey'll fit just fine; I've got a mock up all done and they fit with about an inch of clearance //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
basically, njizfag was makin fun of your box because it was really shallow, but the kid doesnt realize it has to be stuffed behind a crew cab seat, therefore, i defended your designNope, explain yourself.
Um, no. He was saying it was very shallow thus a port on the front of the box was impractical.basically, njizfag was makin fun of your box because it was really shallow, but the kid doesnt realize it has to be stuffed behind a crew cab seat, therefore, i defended your design
