SA 12s
I have the same subs. I build a box for my Ford Taurus for them. 4.2cu ft net tuned to 29hz, double baffle, braced with 1" dowels and 45's on the inside. Just needs a little more sanding and I could carpet it for you. The lows are nasty lol. I have a new car now so I have no use for the box. Id sell it for what I paid in wood for it, you would just have to pay the shipping. Thing is heavy as hell, about 90 pounds. PM me if your seriously interested.
I'm running 2 HDS210s on a hifonics brz1700 at 2 ohms (1200 watts) with no electrical upgrades in a 99 Plymouth breeze. Only time my voltage drops is at night with lights at idle. I've heard hifonics amps are power hogs too. So you might be fine. You will be running at 1 ohm and a little more power so you might not.
Is KnuKonceptz a good brand though? Yeah I have a SAMs club near by, get two of the same battery's?
Yes knu konceptz is very good ..and no get a battery that fits under the hood then get a g31 size..its bigger ..and cca is fine no its not as good as ofc but it will work just fine ..i have all cca wire in my car and run 3 times the power u got
The batt under the hood will be a g34 more than likely they should be able to tell u by giving ur car make and model ..tell them the 2nd battery is going in the back so they dont ask a bunch of questions and try to sell u something else
So a standard output battery under the hood or is that going to be high output as well? You guys are a lot of help! I appreciate this fellas.
U will be ditching the battery u have im there and replacing it with a lot stronger agm more suited for strain of car audio . And the 2md battery will go behind back seat wired to the front one to help with the power consumption
---------- Post added at 06:52 PM ---------- Previous post was at 06:51 PM ----------
If ur at sams they will both look alike duracell agm but one will be about twice as big
Sandin
Sandin
Grand Rapids, MI
Dmac1991
vegang
vegang
