RyanM923's Dual Reflex 6th Order BP build...whew.
what about his 6th order with aeros ??? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
i would have done some form of removable top, or double baffle over the sub and create a removable square in which u can yank ur sub.
other than that, nice build and hope it meats your expectations
I was going to use the aeros but I got advice from someone who had some issues with using aeros that were being used really close to the walls on his box, and that it completely messed up his tuning...so I decided to do it as I originally planned.
I was going to do some kinf of removable top, but I plan on using this box until november, so it's not going anywhere for a while...unless it completely fails(I'm still anxious to see where my peak is at).
I can always tweak the ports a little bit by shaving some off or adding a little, if needed.
Is it your sub? No? Ok then.
Jeez, why is everyone so worried about the price?
It's my money, I certainly made the money, so let me spend it as I wish....I don't see anyone giving RE XXX, DD 9500, DC Level 5, or other $600 sub owners flack for spending that kind of money on a sub...
I do believe I addressed that here:
Don't listen to me though. It's your system and your money, do whatever makes you happy. I can't wait to see the results when you're done. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As I said, you can buy whatever you like, it's not my money. I can't tell you what to buy. You worked for the money so you get to decide what to spend it on. I'm merely saying what I would have done. Good luck with your build, sir. Sorry for getting all up in your thread.
It's not a big deal, I was just wondering why you never see someone say "why'd you buy a 9515?"...it's always "OMGZ!!! Itz teh butt seks!!!!!11one1one!11!"
Where else can you get a 21" sub for that price? The only one I can think of is the IA DP.
$600 for a substage that hits 150+ without trying (and on pretty low power to boot) is pretty damn good. I don't know of many other setups that can match that for the price.
pd8731 just seems to like hating on other people's stuff
No turning back now...all wired and sealed.
8 gauge speaker wire? Hell yes.
Vids of a one note wonder in a box where it can't even be seen sounds kind of boring...maybe a vid of it being metered?
I guess that would work. You could always throw the camera in the top chamber so we can see some excursion
440
634
983
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
927
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
