router bit questions
Hmm so I need a router to cut the hole for my sub? I had my uncle do the straight cuts with a tablesaw and I was going to do the circle with a jigsaw, how perfect do they have to be?
take that 1 inch flush trim bit back.
1/2 is more than enough....lol
Well, 1" works good so you only have to make 1 pass. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Jig saw is fine. It doenst have to be perfect. Router with a jig is just a lot faster. But either will work just fine.
If you let the bit do the cutting and don't force it through the work, you can consistently make single pass cuts without any extra strain on the router with a spiral bit. I wouldn't try it with a straight cut bit, you'll either burn it up, break it or both. Doing it in one pass will also make for a cleaner edge on the cut.
As far as the flush trim bit goes, 1/2" is a lot easier on the router motor and once again, as long as you let the bit do the work, single pass flush trims are not an issue. I've done full profile pattern cuts with a 1/2' flush bit.
im thinking 1/2 in diameter......
mine is 1/2 in diameter, and one inch long
angrytrucker78
angrytrucker78
St Louis, MO
iamamp3pimp
