rockford fosgate 1000bd?
I think it's an OK price. They are pretty much underrated and should do about 1100-1300 RMS on 14.4 volts. I think as long as you don't go under the rated loads, you should be fine.
I love my 2000bd. They're a great series of amps, put down solid power and are underrated, doing on average at LEASt a 100w over rated, on just 12v.
Their only downsides IMO are the size, and not being to drop blow 1 ohm. Other then that, awesome amps:D
thinking about buying a used rockford fosgate 1000bd amp here locally for $200and was wondering if you guys this is a good price and if there is any pros and cons to this amp.
depends on what model year it is, and what kind of condition it is in. I can say it sold for a lot more than that new //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
t1000bd is about 2x is strong as other amps rated the same, and at 200$ ...thats unbeatably(assuming nothings wrong with it)
Let's not get carried away now. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The newer Model i know for sure can give up to 1500 watts@1 with 14 volts or so. If it is the newer model i would say that's a Great price Depending on the condition of the amp!!! Make sure u test it first!!!
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
bolt01
bolt01
hawaii
KINGDELL91
    May 24, 2024
    May 23, 2024
