RMS vs Watts?
You are confused. The sub dictates the impedance (ohms). You said the sub is 2ohm, Im gonna guess that means its a single voice coil (SVC). In this case, you can run at 2ohms and 2ohms only. If your sub is a dual voice coil (DVC), each coil being 2ohms, you can run at 1ohm or 4ohm, only.
creeps228
creeps228
Santiago, Ny
audioholic
