right tweets crackle
  • 2
bradl79
NLR
I tried setting the time alignment on my hu (clarion nx702) and when i increase my space which is in cm the right side has some sort of crackle on certain parts of a song. I have them set on a passive crossover 530ex @0db anyone know what the issue can be? Does not do it on left side and when i have the ta set to 0 i don't hear the crackle
try wire the tweets to a -3db on the passive crossover and see if that makes a diff. weird that it only does it on one side, hope one of your tweets isn't blown
i don't think they are, but it happens on my right tweet and imagining tweet
i am going t o try the -3db and also swap tweets and see if its just on the right side or if its the tweet its self
try swap the left for right rca on you tweeter amp to check if the problem changes sides, if it does it's not a speaker issue it's a signal issue //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
new rca's, ground you rca's..... run rca's a diff direction (away from pwr'd wires/speaker wires)
I reackon it'll be one of the passive crossovers having a dry solder joint or something
i swapped out the rca's from the high rca to the mid rca i have on my HU, and so far so good, no crackle and it sounds cleaner, so i am assuming it must be my RCA, it ***** b/c the RCAs are a 4ch Stinger 4000, so i hope its just the RCAs and not the High HU preout. Think u Side Show
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
5K
bradl79
bradl79
NLR
Side Show
Decebal
    Jun 10, 2024
