Required Electrical for an AQ200d @ .5 ohms.
What does the type of enclosure have to do with anything? //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif I was merely stating that in single cabs, you gain exponentially when the cabin is not sealed, and this is moreso with the 6th order.....
The type of enclosure gains efficiency by narrowing the bandwidth that can be reproduced. Everyone knows this. If my extra motor force gives me another db over your subs or even 2 just to be generous... your box gives you 4-6 db of gain if you did it right maximally flat. THAT is what is has to do with and THAT is why I keep calling you an idiot. You have no clue what you're talking about. Also, where exactly do DDz's retail for 1400?
Are you really making the assumption that every 6th order will be 4-6 dB louder than a ported box? Wow...
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif are you REALLY saying there is a reason to sacrifice all of those notes for NO gain in efficiency? WOW
Are you REALLY saying that more motor force will for sure make it super easy to get a 151 sealed on music? WOW
See? You've been baited.... and you failed miserably.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif are you REALLY saying there is a reason to sacrifice all of those notes for NO gain in efficiency? WOWAre you REALLY saying that more motor force will for sure make it super easy to get a 151 sealed on music? WOW
What notes am I sacrificing? I play with authority from 26 to 60+. In a burp box, yes, a 6th will be more efficient. But this is not one, as you are aware.
In an identical box, what's going to be louder? Lanzar 15's or DDZ 15's? lol come on now, don't be shy, you know there is no denying it.
The ones that aren't in your pass band. Thus the reason for the 6th order. If you gave up no frequencies, and you gained no efficiency over a ported box, then it looks like you're an idiot for going with a 6th order vs a ported box doesn't it? You just wasted a TON of space for NO advantage according to you.
I suppose that depends on a lot of things. What if the lanzars have a lower FS than the DD's? Wouldn't they have an advantage down below the DD's FS?
Not necessarily. A lower FS could mean a heavier cone that requires more power to move it, making it less efficient.
Exactly. There are so many variables... no one could possibly make such a general assumption could they? Again, you were baited and came up empty since it also applies to your DDz argument. That argument only comes down to you being jelly brah... and that's fine. You can be jelly but it doesn't help you argue at all.
MONSONwarrior
Premium Member
Constantly Rebuilding...
MONSONwarrior
Baton Rouge, LA
ahole-ic
