Replacing kicker comp
Bdoza941
I have a 4th order band pass enclosure for 2-12” kicker comp c subs. 2.5 cu ft sealed to 5 cu ft to the ported side with a 7.75x7.75x9.5 port. I would like to upgrade my subs but would like to keep the same box if possible ( can change port size of needed. Any subs that will give me more power and cleaner bass than these kickers?
I recommend the Skar DDX-12s. They will give you massive bump as well as sounding better than kicker. I had kicker, then went skar, and right now am running sundown.... and skar has been the best out of all off these brands in my opinion...
You are higher than a giraffes pussy......
OP
What is your budget and what what amp are you using?
Is that 2.5 sealed for both or is that a each chamber? Can't tell if that is a window brace or a solid brace in your sealed section.
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
At the end I decided to take the dashboard out, since I also had to solve a problem with the heater core. Upon inspection, I could not find any...
10
Bdoza941
Bdoza941
Sarasota, FL
    Apr 26, 2024
    Apr 26, 2024
