Need Sub Recommendations
Looking to get 2 15’s, need some recommendations, looking to get both for under $1k, need something that would sound nice and clean, good sql and spl. Open to all suggestions thank u
Look at Sundown and Fi. Which amp do you have? Which box and vehicle do you have? What is your electrical situation? Details are everything.
2 skar rp2000, my batteries and alternator are good they drop to around 13.3 volts, in a 4.5 cu ft box tuned to 34, i had 2 AB TNT 15’s but im trying to upgrade now.
@NDPTJB your box is Too small at 4.5 cubes For two 15” tnt’s. minimum advised by ab is 2.75-3 per sub and likely more. Also after impedance rise you’re probably not feeding those subs anywhere near 2k probably Closer to 1k each. Get a larger box and bigger amp you’re going to have to anyways if you upgrade subs which you haven’t tapped anywhere near their potential
NDPTJB
CarAudio.com Recruit
NDPTJB
San Diego
denim
