Replace the amp?
WIN27
NYC
I’ve been troubleshooting an issue in my truck for a while now. Here’s where I’m at. 2014 Toyota Tundra crewmax. Stock speakers and head unit. Aftermarket amp and two subwoofers behind the backseats. I had the amp installed when I bought the truck in 2014. A year or so after I wasn’t getting much power. Turned out to be a bad ground. Everything was fine after running a new ground until around the beginning of the year.
The bass just wasn’t there like it used to be. At low volume I couldn’t hear it, or sometimes it will pop and distort (only in the subwoofer). I tried connecting my phone directly to the amp. I still got the distortion. So I ruled out LOC or wiring issue from head unit. I then tried an old amp I had lying around. It sounded much better for a couple weeks. Then it started doing similar.
Last night I took another subwoofer down to test if it was the subwoofers. Different wires to different subwoofers. Same thing. At high volume they sound great. At low levels there’s distortion, they pop. The subs in there are JL 8”W3 from 2014. The first amp was probably 15 years old, the second was about 20. I’m currently thinking maybe the amps just have some bad capacitors or something considering their age. It was a little odd that they both did it though. Any ideas or suggestions before I order a new amp? Thanks
Your signal is probably not good. The loc doesn’t have to be broken for an loc to be a bad solution.
I suspected that at first. I plugged my phone in directly to the amp with a 3.5 to rca and had the same problem. Which completely eliminates the loc
You tried different subs, amp, signal. As improbable as it may be, only common factor here has been your power wires. You have already had ground problems so maybe power cable is on the same boat. I would re-do all the connection points and run a cable from the engine to a strut tower bolt for good measure.
I like this^^^ Refresh your Supply wiring at all your supply connections, to get rid of any corrosion that may exist with a fresh connection.I would even replace old fuses as they do become weak from heat and or corrosion over time. If you havent done the Big 3 yet, I would consider it in the near future as well
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
609
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
You don't have to but with the exception of what is usually high end car audio companies and home audio drivers it can be hard to find just the...
I agree with others, just buy the OFC. My last wiring was oversized CCA, and while it still works, and looked okay when I peeled the heat shrink...
82
The audio frog gb subs do have good output but aren't spl monsters I'd compare them to the w6 output wise while I believe they sound slightly...
96
WIN27
WIN27
NYC
audiobaun
