Honestly it doesnt really matter if you remove it, or add to it as long as the wires are THERE. But... if its easy to remove it like 123 or abc, then remove it. If its a hassle and you have to get your hands all messy and shyt then just leave the stock wiring there and upgrade with the new 4awg wire.
Either way your going to get the outcome of upgrading your wires for more to flow through
Hey man, you near me in PH, as for your question. depends on what you are running and are you planning to upgrade to more power later. the big question is whats your pocket book say. me personlly i would upgrade and replace everything new with 0 that is overkill to a point but then your set for the future.
so i just finished installing 4 awg i just had lying around in all of the big 3, - batt grnd to chassis, alt + to batt +, and engine block to chassis, well idk if it really did anything that i can tell, the headlights aren't dimming, but the interior still is slightly, but mostly i notice a voltage drop in the guage to about 12-13v, its still there even after all 3 upgrades what do you guys think ?
Just add wires. electricity will take the path with least resistance. On my accord i couldnt really replace the wire the way it was all going around and mounted, so i just unplugged the stock wire(from bat and alt) and added the new wire. well sure enough car would not start. so I put the stock wire back. sure it enough it started. so just add wire dont replace.
Me personally, I would replace everything with fresh 0 gauge. You can pick up the very flexible 0 gauge welding cable from any good shop that sells/repairs welding rigs and use that. It's every bit as good as the high dollar wires, as flexible as the Kicker wiring, and WAY cheaper. Then remove the stock crap and replace it with the new wire. Just my .02 though.
