recomend a sub that can take 300 Watts @ 4 ohm
King Alpha
I have a Crossfire CFA 302 sub that can do 300 Watts @ 4 ohm bridged. I'm currently using that amp to power my front speakers (75W x2 @ 4 ohm). I'm upgrading the front speakers and planning to get a new amp for it as well.
The Crossfire will probably be moved into my dad's car to power a sub in a sealed box. So far, the only sub I can find that's rated at 300 Watts is a JL Audio 12W3v3-4. Is there anything like a W3 that's cheaper? Alot of subs I'm looking at takes a lot more power, or are dual 4 ohms, making the sub/amp not match.
Eclipse Platinum is a nice 12" sub, single 4ohm rated. I believe the RMS rating is 400w @4ohms.
I bought mine for $100, and I couldn't be happier with it. I used to have an Alpine SWS 1222 dual 2 ohm 12" sub, and after about a year, one of the coils went out.....I'll stick to Eclipse from now on for a moderately priced sub.
Log onto Crutchfield and grab yourself a pair of Kicker CompVR subs.
A pair of 10's would run you $130/shipped or a pair of 12s would run you $150/shipped.
If you're only going to use one of them then buy the Dual 2 Ohm versions so that you can wire the individual sub to a nominal 4 Ohm load ~ and you'll have a spare "just in case"!
If that's an option that sounds good to you then ask around the board and most likely you'll be able to find someone to give you a referral code to get an additional $20 off of the above prices. There are heaps of members here (myself included) that are former Crutchfield customers that would be happy to pass along the appropriate code as it would not only get you $20 off of your purchase but it would also give the person who gave you the code $20 off of any future purchase for themselves. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
King Alpha
King Alpha
Hawaii
Blunt
