rca stock infinity stereo nightmare
  • Thread starter speaker blowerupper
  • Start date
  • Replies 2
  • Views 944
  • 2
S
speaker blowerupper
Guest
how do i get 2 punch 100's and a 75 for highs all pumping on just one set of pre outs and not loose any power? with the infinity stock stereo in a 95 diamante that had no pre outs and had to put in a rca adapter will i loose power ?
even better than a crossover if you have them built into the amps and wish to use them is a preamp......this will up the preamp voltage from your rca outs, where as the y adapter method will just break down that voltage sacrificing sound quality as stated above me. Most crossovers do not raise the voltage over the rca's, so a preamp would be strongly recommended. Try audio control, some old linear power stuff, Eclipse, and most brands have one........Good luck
No make or model number on it? Do you have an exact picture of the rear and all its glory?
873
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
906
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
761
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
855
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
943
Guest
gregj9
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
