Where do you run RCA wires on a taurus?
  • Thread starter Parmaguy
  • Live activity
  • Replies 2
  • Views 1K
If you can't run them under the trim on one side of the car or the other then use the carpet next to the trip..You will only know its there when you feel it because its pretty small.. They only other thing I can think of without major hassle is to run it down the center of the car under the carpet.
Mike
a coat hanger will help you find the hole that runs behind the back seat into the trunk. Doesn't the taurus have a flip down seat, if not you may need to take the bottom of the back seat out and run under it then through to the trunk a hole should be more visible with the back seat removed
Guest
gregj9
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
