RCA help
electricamp
ND
I have 2 Precision power pc275 amps, each running a Soundstream SPL 10 DVC. I have split the RCA at the back of my KENDWOOD KDC-x859 and ran a set to each amp. If i have just one amp's RCAs plugged in, it sounds fine. If i plug in the other amp...distortion sets in. Any help is appreciated!
thanks
Originally posted by electricamp I have 2 Precision power pc275 amps, each running a Soundstream SPL 10 DVC. I have split the RCA at the back of my KENDWOOD KDC-x859 and ran a set to each amp. If i have just one amp's RCAs plugged in, it sounds fine. If i plug in the other amp...distortion sets in. Any help is appreciated
thanks
what kind of distortion??? like sh*ty sound ? OR some alternator whine[sound changes with RPMs of motor] or a hissing sound. Basicly is the music really distorted or are you just getting noise?
its not terrible distrotion, it just seems like both amps loose power. if i turn one of the crossover buttons on one of the amps on, it seems to run fine? why would that be?
Originally posted by electricamp its not terrible distrotion, it just seems like both amps loose power. if i turn one of the crossover buttons on one of the amps on, it seems to run fine? why would that be?
Do you have an external crossover----or you talking about the one built INTO the amp?
so no matter which amp you plug JUST one set into it sound fine BUT when both sets are running it degrades the sound--------UNLESS you activate a crossover on ONE of the amps-------ummm well ---a HU can run out of signal when split BUT this isn't common. Is the spliter directly on the HU or on the end of a extended RCA cable? if it's on a cable---change try switching the main cable-------i don't know why the x-over would fix the problem. Maybe the HU just can't drive a split RCA---but something is a miss here cause the X-over fixes it. YOU 'd need to put the outputs on a volt meter or scope to see what is happening. Run a test CD and measure the signal voltage at the amp with just one amp wired THEN connect 2 amps and see if the voltage drops
correct me if I am wrong. If you split one set of RCA outputs at the head unit and run 2 seperate pairs to 2 seperate amplifiers, you should not have to use crossovers of any type or anything right? They should both recieve the same type of signal from the headunit and react the same?
thanks
Originally posted by electricamp correct me if I am wrong. If you split one set of RCA outputs at the head unit and run 2 seperate pairs to 2 seperate amplifiers, you should not have to use crossovers of any type or anything right? They should both recieve the same type of signal from the headunit and react the same?
thanks
right----- x-over only has to do with what freq the speakers like
I had this problem once. I'm guessing each amp is running a different sub in one box. If this is the case check your polarity on the speaker wires. You'll probably find that you accidentally got one backwards. this would one sub to pull in while the other is pushing out, effectively cancelling eachother out.
Originally posted by sforget I had this problem once. I'm guessing each amp is running a different sub in one box. If this is the case check your polarity on the speaker wires. You'll probably find that you accidentally got one backwards. this would one sub to pull in while the other is pushing out, effectively cancelling eachother out.
good call:D
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
980
No make or model number on it? Do you have an exact picture of the rear and all its glory?
781
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
781
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
671
electricamp
electricamp
ND
chris229
    May 24, 2024
    May 23, 2024
