RCA distribution blocks?
  • 2
To my knowledge there is no such thing.....
Other than Y cord adaptors, your best bet would be to look into a line driver or an inline EQ/DSP unit. These allow a single or Triple RCA input and offer several RCA outputs- each having adjustable frequency control. Audio Control Makes some of the best Processors and EQ's in this industry, and offers a great backing of thier products.
http://www.audiocontrol.com
take it easy,
-zane
Okay, I've been looking at cross-overs and line-drivers and I've come up with three competitors for my money. Adiobahn, US Acoustics and Audio Control. Now my only question is: if I use one set of inputs, will the signal go through all of the outputs?
Audio Control, without a doubt. They have been designing these things quite a bit longer than the other two mentioned companies. and have also won more awards in design.
Really it depends on the model you get to determine signal dispersion, typically- if there is only 1 input and 3 outs- the signal would be transfered to all 3 outputs. However, if there is more than 1 input, the outputs are likely separated also.
take it easy,
-zane
No make or model number on it? Do you have an exact picture of the rear and all its glory?
808
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
817
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
698
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
813
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
922
bootleg
Got Adire?
bootleg
San Antonio, TX
zane
    May 31, 2024
    May 24, 2024
