Rattling
Originally posted by kookysmonsta With the spray whats the best kind or brand to use?
it not the kind or brand RATHER the amount of weight it adds. The more the better----- the addded weight changes the resonate freq to a lower one. This makes it vibrate less and less. I used cheap $7-10 a roll mat on my car-----from http://www.mcmaster.com look under damping then find the HIGH TEMP MASTIC
brown bread (not literally brown bread, it's dampening material) near your speakers, and Dynamat works well also. Dynamat has a license plate cover that takes away license plate rattle. Also, for the license plate, you could buy some felt hardwood floor protectors. Punch holes in them, and put them on the screws when you screw it on, also putting them on the corners.
my gas tank rattles more than anything else. i took off all my talk lights and liscense plate and took a rubber hose and spliced it in half and put it around everything you can see it but it helped alot
Never did tear them down since they still play happily ~200 watts over rms for hours every day lol
50
7K
I would clean the paint off that location and use two washers to sandwhich the ground wire to secure a solid connection and use a bolt rather than...
27
3K
Deadener is probably the best option. I completely gutted my Mini so I could apply deadener everywhere I could reach. I have used FatMat with good...
863
kookysmonsta
kookysmonsta
savannah ga
Fuel37
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
