Rare Pair of 12" TC Sounds Prototypes
ciaonzo
TheContinental
11,703
76
WI
(2) 12" 3HP prototypes. Extremely rare, the only two I've ever seen or know of.
Only selling them as a pair.
Musical and beastly.
Very long coil (3.5"WW), massive copper sleeve on the pole. Crazy power handling.
Never used, only tested. Essentially brand new.
Specs:
Dual 2ohm
Re = 1.5/coil, specs pulled in series.
Fs = 25.8894 Hz
Zmax = 38.7039 ohms
Qes = 0.5122
Qms = 6.0229
Qts = 0.4720
Le = 0.9676 mH (at 1 kHz)
Diam = 246.3800 mm ( 9.7000 in )
Sd = .0477 m^2( 73.8981 in^2)
Vas = 24.6562 L ( 0.8707 ft^3)
BL = 21.8359 N/A
Mms = 494.9209 g
Cms = 76.3590 uM/N
Kms =13096.0332 N/M
Rms = 13.3669 R mechanical
Efficiency = 0.0785 %
Sensitivity= 80.9664 dB @1W/1m
$650 plus half of shipping (CONUS) from 53527. Heavy mugs.
No trades, please.
Tops and motors will ship separately to avoid damages.
More pics and info on this link. --> http://www.caraudio.com/forums/subwoofers/478546-if-you-like-tc-goodness-bring-jerkins-some-tissues.html
Thanks, Parker.
sobe3yourself, these are very well suited for tiny sealed enclosures - Low Fs, nice medium Qts, tiny Vas, and massive power handling. Sensitivity is not on your side, though. You'd need plenty of power.
what are the recommended specs for ported and how much wattage should we give them? Im in search of a power 12 similar to the xcon/dp/level xl.
Honestly, I wouldn't even bother with a conventional ported enclosure. Ever try to model a 1 cubic foot enclosure with a 25Hz tuning? Might as well build a TL, lol. I would highly recommend going small sealed with these or using TC Sounds passive radiators with them. Thermal power handling won't be of much concern but I would use at least 1-1.5k on each to start with.
I was very interested in these speakers until i read this… They dont perform well ported?
That's not at all what I said. I recommended using passive radiators instead of conventional ports, lol. Almost exactly the same thing as a vented enclosure but better in most respects when done correctly.
will the TC Sounds VMP 12" Passive Radiator work? How big of a box would it require if we ran one with this PR? I am interested but not in the pair..anyone wanna split?!!
Yes, as I stated above your post, the TC Sounds version in particular because it has similar excursion capabilities and compliance parameters that will best suit the tiny enclosures these drivers want to see. As far as enclosure size, did you notice the Vas figure?
If we shoot for the ubiquitous sealed alignment Q of .707, by simply plugging the following formula we get one very tiny enclosure to try and shoehorn a monster of a 12" into.
Vb = Vas / (( Qtc / Qts )^2 - 1)
24.656 / (( .707 / .472 )^2 - 1) = 19.825 liters (approximately .7 cubic feet)
For use with a PR you might bump the volume up to .8 cubic feet per driver.
I will not split these drivers up.
I like the MA Audio HK series ..ive ran and won with them at car audio comps
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
    May 12, 2024
Brendon Jenness
    May 11, 2024
