" Y " on RCA cable ?? HELP
boutchsk8
Québec
* sorry for my English i'm french *
Hi, I have a little problem and I will need help. I reçently buy a new radio and my radio only have 4 RCA plug in the back. I would like to know if it's possible to connect my 2 amp (one mono for my sub and one 4 chanel for my speaker) to this kind of radio or I have to buy a new one whit 6 RCA plug ?? Maby I can use RCA Y-adapter ? or any solution guys ?
Thanks for your time !
No make or model number on it? Do you have an exact picture of the rear and all its glory?
671
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
673
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
591
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
755
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
891
boutchsk8
boutchsk8
Québec
Side Show
    May 18, 2024
    May 18, 2024
